Hi all, I have got myself a fairly new Indesit IWME 126 from a local auction. It was a 14 day return or similar.
The problem is that it refuses to spin it's drum. The water inlet valve works fine, and it will drain fine too. What it won't do is run any program that requires the drum to turn.
On the spin program, it drains fine, then waits some time, then drains again, as though it thinks it is spinning the drum.
I have had the motor off to see the condition of the brushes, and as I suspected they are fine (it is less than a year old according to one label I have found stuck to it)
Does anyone have any ideas how I can go about troubleshooting the problem.
cheers
cheers
