Indesit trouble!!!
10 Mar 2016
I have an Indesit condenser dryer and it is taking nearly a full day to dry a load! I am not overloading the dryer. All filters are cleaned and the water tray is emptied before each load, there is heat also. Just don't understand why it is taking so long to dry a load. Any help is appreciated
Have you hosed out the condenser found at the bottom under the flap
Is that the tray at the bottom of the dryer at the front? Also had that out and cleaned it out?
It's a big silver condenser about 12 inches long and 6 inches wide. It pulls out and must be hosed out not hovered out.
Oh yeah I know what you mean, it collects all the things like coins and other bits and pieces, will it make a big difference if I pull that out and hose it down? I do look after the dryer but don't know what else to do?
Yes it will. Check the amount of fluff in it.
