Indesit w103
2 Nov 2006
Hi there,
Indesit w 103 M/C almost 4 years old. It fills with water ok then agetates washing for a bit heater appears to kick in and water gets hot. Stays like this for ever if you let it and does not move forward onto wash / rinse etc. If you reset I can get it to empty but little else and then aborts. I Have checked heater for continuity OK and the motor brushes look good. Have read other posts about blown PCB's, poor connections I have looked at and remade connections all appear ok. Someone suggested the thermostat on the heater element? Don't know what sort of resistance / continuity readings I should look for? Filter and outlet all clear no blockages.
Any suggestions apart from take it to the tip
Cheers
