I have a 2yr old Indesit washing machine. As with other posts i have read, when selecting a program, the drum fills....then nothing but electrical hums.
Sometimes the programme dial does turn of its own accord and i have to reset, once reset it stops turning. If i manually select drain it will drain away, then rotate on the dial when it should spin. Also on spin setting, it starts to spin then stops when fast spin should start and the dial rotates!
I have opened the filter at the front and cleared all water but there was no blockage i could see in this, and on resetting and trying again the same thing happens......CAN ANYONE HELP PLEASE!!!!!......
