Indesit W143 error
29 Oct 2006
Leicester
My indesit W143 washing m/c continually tries to drain with the program selector continually clicking round, the LED repeatedly flashes 10 times with an interval of 10 seconds.
have checked the filter & all seems ok, any ideas please.
many thanks
steve
Hi.
10 flashes indicates a fault in the pressure switch area. Check for loose conections on the pressure switch and module. Check for operation of the switch by removing the clear tube on the switch and blowing gently into the switch, you will hear it click once. When the pressure is released it will click again. Also try blowing into the tube, you should be able to blow quite easily.
This fault can also mean a faulty module if your very unlucky. Hope this helps.
Eric.
