What do you expect with the lack of effort you have put into providing any useful information that may assist anyone coming to a knowledgable conclusion as to the possible fault ! and hence making any recommendations...
sorry bathjobby - haven't done this before - what do you want to know? It doesn't spin and it leaks. Have tried all the reprogramming checked filters and pipes for blockages. Leaking is from the door and soap dispenser. Drum goes around if you push it manually and there is a slight swishing noise as if there is water underneath the drum.
Hope that helps and apologise for lack of information.
