I have an Indesit WAshing Machine, an W165TX that som times have the spinning dial problem. Ive put it on stop program, but i have trouble reading the fault code, it goes to fast. Sometimes i think its an 4, and sometimes a 3.... What does those codes mean?
It started with the preassure switch, it said it was faulty, but i took it apart and cleaned the burn marks on the switch (normal use burnmarks in a relay) but no change. Then i checked the hose to the switch and found that it hade wearholes in it. replaced it and the machine worked. For one wash.... then it started to spin the dial when it put some water in...
HELP!!!!
Hope my english is understandable, im from sweden...
HELP!!!!
