when doing washing the machine goes through the wash cycle o.k. but when it reaches spin cycle the switch just turns until it reaches the original start point.as anyone got any suggestion as to the problem.
OK, bit of a long shot this one.
These machines are notorious for throwing up wierd faults. There are several things can cause this but the main one is the motor carbon brushes. Even if they look ok and have plenty of wear left they can cause errors.
Not sure how expensive they are but might be worth trying a new set in the motor.
