Indesit Washer/Dryer pressure switch not sensing
13 Jan 2010
Yorkshire
Hi Guys
I have a faulty Indesit WIDL126
The error is:
f10 lights 1&3, pressure switch not sensing
Has anyone had this error,
What needs replacing?
What is the likely cost?
Does it need an engineer?
Cheers
Rob
check connections on pcb are tight, otherwise a pcb is neded recon one 45 .00 from emw ,
ah so it's the PCB, i saw your answer for another topic that suggested replacing this
first of what does PCB stand for
Where is it located - is it shown in the Manual or do I need a service manual?
pcb = printed circuit board, found at the rear of mc in the corner remove rear panel all is revealed .
no none , remove rear cover at the back pcb is in the corner at the back tucked away in the back left if looking from rear of mc .
110498072439 ebay , this is what your looking for .
