indesit washer/dryer trips rcd
17 Sep 2005
Cardiff
my indesit widl126s tripped the rcd in the consumer unit halfway through a wash cycle - i took the cover off the pump filter and the was a cotton bud stuck in the pump impeller - ive tried switching power on with the pump disconnected in case its blown but keep getting the same - leds flash on the front panel - then it trips the board - any ideas ? thanks
can u get hold of a meter .its either the top heater or bottom heater or mains surpresser shorting out .could also be heater wire on top cut .
