I have an Indesit WD12x washer dryer which leaks from the soap dispenser drawer housing. I have removed the lid of the machine and can see that the there are 4 plastic clips on the outside of the curved part of the housing and the water drips out underneath the 3rd clip, around 1 drip per 1 or 2 seconds, onto the drum . I have not undone the clips as the drawer housing narrows off into a straight section that connects to the water inlet pipes, and I don't want to undo the screws holding it down in case there is a gasket that I might disturb. If I could open these catches it looks like the housing would open up (like a sandwich toaster). The housing has a 5mm lip running round the top and a 9mm lip on the bottom section. It looks like there is a 9mm vertical split in the plastic on the bottom lip inbetween the 2nd and 3rd clip. The soap dispenser drawer is clean and I have poked a pipe cleaner into the water holes that feed into the soap drawer. Do I need a new housing or is there something easier I can try. If I need a new housing, do you know what part number I need and is it something a girlie can do!? On a less important note, I have given up using conditioner in the machine as it just tends to sit in the drawer and doesn't go anywhere! The liquid detergent always disappears, but not the conditioner. Any bright ideas? Many Thanks, Caron
Read more: //www.diynot.com/forums/viewtopic.php?t=216193#ixzz2JNTvqs
