indesit washing and dishwasher problems
2 Dec 2008
Lincolnshire
hi to all firstly i have a problem my idesit washingmaching wil103 and dishwasher idl40 have both suffered heating problem well that is what im thinking they are there both cold water fed and donot appear to be heating up would anyone know that if i was to gain acess to the heater elements and using a ohms meterto check the heater elements out would i be going down the right road!!! what readin would i get for both appliances if there in good working order thanks would be much help if my question could be answered
put washer on 60 degree and feel glass door after 30 mins is it hot ,if not it should stop after the wash cycle and stay on that programme and wash for hrs on end ,dishwasher put that on quick wash and open door after 15 mins is it hot, lights should flash to a fault code .both heater should be 25 30 ohms washer heater is at the back remove panel and heater is at the botom .dishwasher heater is at the bottom remove base 6 screws and you will see it
hi there many thanks for the reply i will get to work this weekend and let you know the results thabks again
