Had a problem with a blocked condenser which I sorted last week. The machine ran perfect for 2 days then began blowing cold air through, have changed the element and the thermostat but still no joy, fan motor is working ok but element is not heating up. HELP
Not sure about the models but check the wiring to the heater/stats for a thermal fuse. If the cable passes under a clip held by a screw on the top of the heater box then this cable is your problem.
Power off before working on the appliance please.
