INDESIT WD10 fills up and leaks through the front
20 Jun 2005
London
Two days ago my WD10 started clicking around the program and would keep going until turned off. Wisened from past experience, I checked the filter and found two coins and a cuff link in there.
I removed them, and the clicking stopped.
Now, as soon as I turn on the machine, it starts to fill up, and filling up continues even when I put the program on drain. Eventually the pressure get too large and rubber lining of the front door gives in, leaking water everywhere.
If I turn off the incoming hot/cold water taps, the machine works normally.
Sounds like some kinda stuck detector for water level, but I have no idea where they're hidden in this model. . any ideas?
thanks!
Tom
no idea what so ever, but it could also be the pressure chamber blocked / partialy blocked, try a search
