INDESIT WD125 WASHING MACHINE 3 flickers no go!!
14 Dec 2006
Tyne and Wear
:( any body help? turn w/machine on at mains,program set,mains light flickers,3 times then solid, at this point it needs to draw water,within a millisecond of attempt to draw water, the whole ring main trips.!? have been inside removed/replaced pcb conectors(in correct order) sprayed switch cleaner to reset,but still the same what can i do as my smalls are starting to pile up?? :(
Hi, I'm no expert & can't explain the flickering light - but it sounds like the inlet solenoid coil is short circuit perhaps?
