indesit WD12S fault
6 Jan 2006
Nottingham
Can anyone help,
The above machine is showing a fault ie 11 flashs, will not pump out. I have emptied the machine and checked the pump, filter and pipe for obstructions. The machine seems to perform all of its other the functions seperatley however the selector button on full cycle contiinues to move around the dial.
As you've probably guessed 11 flashes means the pump isn't running.
Possibilities are faulty pump, faulty wiring, bad connection to module or faulty module.
Unplug your appliance before working on it.
