indesit we8x
4 Feb 2006
Leicestershire
indesit model we8x. filling and draining, no problems there. even spins. but will not start a program. or any cycle. when you start it, it jsut fills and then you can only empty it. flashing an error code h20?? all pipes have been checked and seems to be ok? have no idea what the problem is or how to fix. any one have any ideas or tips, be very grateful. its 6yrs old
hi it could be the motor or the carbon brushers on the motor. unplug machine befor you look at it
hi mate. many thankx for the info help. unable to get in and look at the brushes as need an engineer for that. think i might need to call one now. thought we had it working, then it stopped and started flashing h20 errror and now f7 error? any ideas what they mean?? before i call an engineer out? thankx
H20 is a problem with water, normally not filling. F7 is a heater problem, either heater, wiring or relay on the module.
Unplug your appliance before working on it.
thanks for your help. i called an engineer out, he confirmed most of what you said. we basically need a new machine now. but your advice was very hady. much appreciated.
