Indesit WG1034T
4 Nov 2005
Clwyd
The washing machine does everything apart from the fast spin at the end which is obviously annoying! Granted, its a few years old but were moving house next month and just want a cheap, quick fix before buying a new one after Xmas. PLEASE HELP!! :(
There is a chance that the machine is draining too slowly and water in the tub is inhibiting the spin but these machines are prone to a type of timer malfunction that also gives this symptom. If its a draining problem you can usually get it to do the fast spin by doing one or more additional spin cycles.
fido is right to check pump first.
he's also right about the timer.
i've found in many cases that by removing the multiplugs from the timer and tightening the connections the machine wil spin fine after that.
Thanks Gents. Is it straight forward to remove the multiplugs from the timer? If so, how do i access them?
take off the lid and they are on the underside of the timer. easiest for you would be remove one at a time. nip the connections SLIGHTLY and replace. only afetr checking the pump first.
also one of my customers today had the same fault. guess what! she'd pressed the spin cancel button. have you? and before you ask, no i didn't charge for the call.
Thanks Keith. Will have a look tomorrow hopefully when i'm off. When you say take off the lid, do you mean the back panel? Sorry, i'm no expert on washers!
