Indesit wg11301 drum leak
19 Jan 2012
Berkshire
Drum leaks from the join of the drum & drum back. ( & over the motor connnector, great!). There is big circular clamp around this join, once removed, the drum back doesn't come free. How do I get this drum back off? What makes the seal? Is it a rubber seal, but there was a lot of white powder in the joint ! . How does the drum come out of the machine? out the top? ( u can't get the concrete block off because of the cross bar, held by the springs, held by the weight/size of the concrete).
The clamp unbolts and so does does the pulley , the back half pulls off and comes out then there's the rubber seal that's faulty.
Thanks, but when it came to the back was stuck fast so I settled for a good layer of sealer under the big circular clamp, and a piece of plastic bottle under the motor bolt to shield the electrical connection if it should ever leak.(but clear of the motor & connector incase of heat) The original fault was "no spin " due to the water on the connector. 1 month passed OK
