indesit WG924
1 Aug 2007
Glasgow
theres a kind of rubbing/grinding noise coming from my machine when the drum is at the fastest point in the cycle. I took the back panel off and the noise seems to be coming from the Bearing Hub Assembly...is there anything else it could be? or will replacing that do the trick?
Cheers,
Alan
cheers for the reply. I'll give it a go. I just wanted to check before buying replacement. Any advice?
only advice is dont do it.
seriously, the parts are cheap, but you should also change the spider (drum support) since it is this that caused the problem to occur in the first place.
Its not easy getting the bearings out unless you have the right kit, then you have to get the new ones in, and flat.
good luck !
