indesit wi101 not draining
11 Oct 2005
hi there have a indesit wi101 and it refuses to drain, also the selector knob just keeps clicking round ...... any ideas ??
the selector clicking round is to make you aware there is a fault. if you can pull the machine forward tilt it back at 45 degrees, remove lower plinth, filter is on r/h side, remove it and chech with torch that there is nothing in there and that you can turn the small impeller right at the inside back of the filter, if that all ok it could be sock in sump hose,1st thing to check if the waste joins into plumbing under sink is that connection is clear. rgds gary
