Indesit WI101UK problem
17 Apr 2007
Hi, please can someone help me.
My Indesit WI101UK washing machine is faulty.
Shortly after switching on, the dial clicks around and the led flashes 8 times.
I have checked for blockages and have also replaced the heating element as it was covered in limescale.
If I unplug the machine for 30 seconds, reset the dial (normally to program 4), plug it back in and switch on, it runs fine (70% of the time).
Please help before my wife posts it throuth the window!
Fault F08 - heater relay stuck. The most common problem for this is the pressure switch sticking. This is the fix - unplug appliance from mains, remove top, disconnect pressure switch hose from switch, tap switch on tor weight a few times, refit hose, reassemble and test. If this does not work check wiring to heater and meter.
Thanks scotty!
I'll try that on Thursday night (watching son playing football tomorrow night) and let you know.
Thanks again for the quick response.
Hi Scot,
I have made sure the pressure switch is working, cleaned the pipe leading to it and the pressure chamber at the bottom.
The problem is still there.
I have physically checked the wiring and it all seems secure.
Any further suggestions would be much appreciated.
Adamp
