my indesit WIA111 cold fill washing machine seems to have developed a fault, it seems to be stuck on the same programme, i cannot change the prog or the temperature, and when the on/off button is pressed it stops, but the top led button(wash cycle) stays lit. when switched on again will start without new prog being set... i have to leave the door open as when closed it will constantly run through the stuck prog over and over again..please can you help?????????
