Indesit WIDL126 Not Working
8 Jan 2010
West Lothian
Hello
I have an Indesit WIDL126 wahser/dryer.
On any cycle the machine fills and then drains a little. The machine then spins a couple of times, slowly, and then stops and does nothing else.
I then have to reset the machine and run a drain cycle to get shot of the water.
So far I've tried unplugging it and cleaning the pump filter. I've checked the cold water inlet and drainage pipes and both look ok.
Any ideas?
Many Thanks
Mark
It should fill twice , check the valve is not open circuit does it fill on rinse , blow down presure pipe as well
The machine only fills once.
It drains ok when running the drain cycle.
I've taken the back and top off and can't see any lose connections.
Could it be the carbon brushes?
Did you check the rinse prog , does it fill on that prog if no valve open circuit.
