Indesit WIDL1265 Problem
5 Nov 2009
Belfast
Moved house and put my Indesit in today, switched it on and after 20 mins or so it was not doing anything.
The door lock led was flashing rapidly and the 'easy iron and 1200-1600' green leds are flashing.
I tried googling this problem and found that a few people have had this problem but there wasnt any answers.
I figured out the flashing sequence of the leds must be a fault code but I do not have the manual and can't find what the fault codes mean anywhere on the internet.
Any help would be much appreciated.
Thankyou,
Chris.
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
f1 and f17 share the same light
Thanks, looks like its this:
f05 means filter /pump blocked needs a clean. found at the front under kickstrip .
also check sink waste spigot poss not been cut off as you just moved in.
Right that bit was blocked, with polyfiller of all things, got it cleared now and cleaned the filter also.
Hopefully this will have fixed the problem, just trying a wash now (fingers crossed)
