Hi everyone,
I'm having problems with my Indesit WIXE127 washing machine. If I set any of the programmes the machine keeps loading and pumping in water and doesn't stop. It therefore doesn't spin.
I am able to drain the water via the drain setting on the machine so this would indicate the there is no blockage.
If I set the spin setting on the dial, the washing machine spins so the belt appears to be working ok.
I've checked the filter for any blockage/obstacles but I couldn't find anything in there.
I'm testing the washing machine without any load at the moment because when I had a load of clothes in there it stopped working and they were soaking wet so didn't want to risk it again. If there's no load should the machine keep filling up? Is it ok to test the washing machine without a load?
Does anyone know what else it could be?
