Hi Guys
Im after a bit of help with my Indesit WIXE 127 model it shows Fault code F-08 on front
display, what areas should i be looking at, it has ran fine for 5+years
Hi rocks1
Thank you for that information, whilst waiting i had a bit dig around
and the short answer is i found andremoved the control module, and its cover
exposing the pcb, and on it was some square relays, i gently gave
them some gentle taps, then put all back together again looking
for loose wires, then i put washer on a full empty program and
machine worked straight away, with no F-08 code on !!
But i have looked on EMW as you say and found the right
PCB for my Machine "Indesit Mark 4 Washer Computer Board SKU: IM0004"
in case the problem arises again, and i know now how to fix...
