Hi again folks think was barking up the wrong tree with motor triac fault as i thought the problem was the machine will spin on spin program but when i try to run a program, it fills then flashes the 4th extra rinse and door lock lights and starts to empty the drum, then keeps trying to empty even though there is no water in the drum. have checked the pressure switch by swapping it out with another switch and checked the pressure hose, both seem good. also seems to over fill on rinse program.
Any ideas as really could do with getting this up and running?
