I have an Indesit WIXXE 127 Washing Machine which has begun to make a clicking sound during the cycle.
It seems to have started since washing a bath rug (on its own). The machine tried to spin the rug and I think it must have still been heavy with water as it caused the machine to vibrate a lot, move forwards slightly from its position under the counter and make quite a bit of noise. The machine did complete the end of the cycle (including the final spin once it had drained more water).
Since then there seems to be an intermittent clicking noise during the wash and spin cycles. The machine is showing no fault codes and apart from the noise it functions as normal.
When the machine is not running and I manually spin the drum you can't hear the click. If you push the drum backwards and forwards then you can. The noise seems to be coming from towards the top(?) left of the machine as you look at it.
The machine is about 2 years and 3 months old, though my good wife tells me she thinks she uses it approx 12 times a week (so I suppose it real age is a fair bit higher!).
I have watched various online videos but can't seem to find an exact match.
Can anyone advise me on whether or not I should do anything about the noise? (or just take my chances and leave it to run). Is the machine likely to be safe with this clicking (I don't mind risking it dying if that's the sensible option, but I don't want to gamble if it may go up in flames). Does this point towards a certain part that needs changing? If so, is this a straight forward fix I can attempt myself.
The machine has a valid parts guarantee, but Indesit charge a call out of £110. Given how much usage I have had from the machine and that it would likely cost approx twice as much to buy a new machine, I don't see value in getting them in.
Thank you in advance to anyone who is able to give me any advice on this.
