indesit
30 Mar 2005
Same problem, same brand, same month : the belt is OK, motor brushes are OK, motor spins no problem with no belt so I assume the motor is OK which leaves out of balance ... how does that work ... or not ? :confused:
______________________
Moderator
split from hi-jacked post, please see 20 ;)
Have you tried a spin with the drum empty? That should confirm if it's a balance problem.
