Hi all
I've has a good search and spent time on paving expert so please forgive me asking about this well trodden subject.
I am planning to lay a 90 sqm Indian sandstone patio (riven) over the jubilee weekend. Lots of advice out there but it all seems to differ slightly.
So far all i've done is hire a digger !
The area i am laying on around the house mostly well compacted clay soil. I was going to excavate to a suitable depth and lay the following;
100mm of hardcore. Whack it down.
50mm of MOT type 1 crushed stone. Whack it down.
50 of wet mix bedding for the slabs
22-25mm of Indian sandstone.
whilst excavating I was going to grade the soil away from the house at about 60:1 when follow this up through the layers to give me my run off.
Patio will be foot traffic only.
I need to be very clear about the layer thicknesses as I want the finish floor level to be at a specific height against the house.
I also have to incorporate a few trenches for a low wall and drainage.
flag sizes are
900 x 600mm
600 x 600mm
600 x 300mm
300 x 300mm
laid in a 'random' pattern.
so questions;
- Does the above sound ok ? ie thicknesses of layers etc ?
- should I be asking for any particular spec of hardcore or sub-base ?
- I have seen a number of posts about using a membrane in the layers, assuming this is to stop weed growth.
- Any advice on bedding mix and point would be great.
Thanks in advance.
Wert
flag sizes are
900 x 600mm
600 x 600mm
600 x 300mm
300 x 300mm
so questions;
Thanks in advance.
Wert
