Indicators not working on my Renault Zoe EV
17 Oct 2005
Ireland
Hi all, - the Indicators have stopped working on my Renault Zoe EV.
If I press the Hazard switch on the dashboard the 2 green indicator lights on the dashboard flash as normal, but no indicator lights show outside.
Then if I turn off the hazards and start the car and put the right indicators on the green right indicator flashes on the dash , but only twice then goes off. - no lights showing on outside.
then if I put left indicator on the left green light comes on the dash as normal …. but for 2 times and then goes of , again no indicator lights show on the outside.
However- if now I press the hazard switch or try the indicators again - absolutely nothing , no lights no ticks no indicators showing outside the vehicle, no green lights on the dash - totally dead (indicator/flashers wise)
If I turn off the car and lock up 10 minutes later come back it kind of 'resets' itself and so I can put on hazards and green lights on the dash flash and the ticking noise is there (I predict its a speaker behind dash rather than physical mechanical flasher/relay) - again absolutely no indicator bulbs flash outside.
I have tried taking out every orange indicator bulb (bar the drivers side mirror indicator bulb because I ran out of time) to check to see if any were blown and they werent. - But here is another strange thing , with the 2 rear orange indicator bulbs removed I was expecting the hazard green arrows on the dash to flash erratically light they normally do when an indicator bulb blows or is removed but instead they still flashed at the same normal rate! - I thought that was strange.
I have checked all the fuses in the UCH box under the bonnet by the 12v battery and they are OK, not blown.
I have not had a chance to check all the fuses in the glove compartment fusebox yet.
Screenshot of what diagnostics threw up:
I don't know the answer either, but in 'normal' Renaults the hazard switch itself was known to cause all sorts of issues.
I think I'd be heading to the dealer if there are no alterations or repairs done to the car.
John:)
John:)
thanks i will hook a meter up to the hazard lights switch and see
