I have found these forums helpful for many years - I'm sorry I haven't registered before now!
I would be grateful for some help with some Qs about the heating system in our new house. We have an unvented indirect megaflo water heater (CL250HE) which also has two immersion heating elements, and a Worcester Bosch gas fired condensing boiler (Greenstar 30 CDi).
I understand broadly how the system works to heat our water, but I want to clarify a couple of things.
1. Our programmer has separate timers for the heating and the hot water. As far as the hot water is concerned, what will the programmer switch on and off? Is it the immersion heater which is part of the water heater (for back-up and top-up, and summer use, I guess?), or is it something else?
2. Will the boiler pump heated water through the coil in the water heater every time I switch the central heating on? In other words, do I need to switch the hot water on (using the programmer) when I have the central heating on?
3. The boiler itself has two thermostats - one for the radiators, and one for water. Does the water thermostat actually do anything? If so, how does it work, if the boiler is simply pumping water through the heater's coil in the same way (and at the same time) as it pumps water through the radiators?
4. After bleeding the radiators, I topped the boiler up so that it had 1 bar of pressure (it ended up at about 1/2 bar). Was this the right thing to do?
5. Does anyone have any tips on how long the hot water and/or the heating needs to stay on to get enough hot water for two adults and a toddler?
6. How long does water stay warm in such heaters after the heating is switched off?
Finally, I have a question about wireless thermostats. The new house has one. The previous owners kept it in their bedroom. The valves of the radiator in that room have no means of being turned by hand - only the spindles are showing. Is there any reason for this?
Related to this, this radiator seems to get much less hot. I am tempted to turn the spindles so that they are fully open. Is that wise? Is there any particular reason why this radiator would be kept cooler?
Thanks so much for your help. I am trying to get someone to come and service the boiler and heater, and I hoped hoped to pick their brains, but in London SW17 no one seems too bothered about taking on that kind of work!
