Like most people, different rooms in my house require different levels of heat.
I notice this in my office room, which has a lot of computer equipment in it, which means I am either baking in there when the CH is on, and the rest of the house is fine, or temperature is fine, and the rest of the house is freezing.
Solution appears to be to fit individual radiator thermostats.
Can anyone tell me the following?
1.) Where on the radiator do they go? (e.g is it in place of the valve at the bottom of the radiator, which controls the flow?)
2.) Are they easy to fit/ how do I fit it?
3.) Is this the same as my just reducing the flow to the radiator using the shut off valve currently at the bottom of the radiator (inlet pipe)?
