replacing gas with induction hob. 32A fuse at consumer unit, isolator switch in kitchen. Dedicated circuit for 'cooker'. Already have a 2.6kw oven hooked up and there is a second cable being used for the ignition of the gas hob.
confirmed 6mm2 from consumer unit to isolator switch, but only 2x 2.5mm2 runs down to behind the oven. So I'm limited on power and I don't think we can replace the wire with 6mm without a lot of mess.
Bosch have what I thought is a good compromise - a 3.7kw induction hob - so well within the limits of 2.5mm2 but it has a plug on it 'for easy plug and play, no electrician needed'. Reading the instructions it seems you can set it to 10/13/16A as required. But the instructions also say
so I'm confused. The obvious answer is 'chop the plug off and hard wire it' - there is already a faceplate for a hard wired connection. But AO say they won't cut off the plug as it'll invalidate the warranty. I rang Bosch and they said you can cut the plug no worries as long as its installed by an electrician the warranty is valid.
I just find it confusing they ship with a plug but also 16A capable. Wouldn't it be easier to ship without a plug and give you the option to wire a plug on if you want to just stick in a socket?
Anyone come across one of these 'plug in but also 16A' hobs?
- Power management options for 16A, 13A or 10A connection: limit the maximum power if needed (depends on fuse protection of electric installation).
- Power cord 1.1 m UK 3 pin plug: plug and play, no electrician required for installation.
- This hob is equipped with a UK 3 pin plug for an easy plug & play installation. The plug limits the maximum power output to 3.7 KW. For higher power output, please select a hob without plug and ensure installation is carried out by a qualified electrician.
