I've just purchased an induction hob which I want installed in my kitchen along with the existing double oven.
Double Oven is Candy FDP 231/X rated at 4 kW (Max. absorbed power)
Induction Hob is Hotpoint ET6124X rated at 6.6kW
Double Oven is currently connected to a cooker plate then on to a cooker switch with a built-in 13A socket then over a length of 5-7m to a 32A MCB...
Should I/can I be asking for the sparky to wire the induction hob into this circuit and the double oven into a new circuit using 6mm2 wire, a cooker switch with no socket and on to a 16A MCB.
Assuming that's ok the wiring will need to go under the floor is this something I can do in advance the guy?
Final questions, the manual also talks about using an onmipolar circuit breaker. I've googled this but I'm not sure what this really means, what should I be expecting when the work is carried out, how much should I expect it all to cost and what's the best way of finding a good sparky (SE London)?
