I laid a patio a while ago using Marshalls Saxon paving flags, 3 different sizes, laid in a random pattern. I thought that I would make a feature of the joints between the flags by having them around 40mm wide. The flags were laid on a full bed of sand and cement and the lower half of the joint was filled with sand and cement also. Once this had dried the top half was filled with small (around 10mm) decorative stones.
The problem is that the stones keep coming out of the joints and end up all over the flags. One thought I had was to reinstate the stones and then source some sort of clear adhesive product which could be poured over the stones into the joint and this would then set hard and keep the stones in the joints. I have searched the Internet but have not been able to turn anything up.
I would appreciate any suggestions if anyone has used any similar products previously. Thanks.
