Infinite Prime PIR
17 Feb 2013
Sussex
I have a wireless Infinite Prime system that is displaying a low detector battery message on the control panel.
I have replaced the battery but low battery message still displays on panel.
Any suggestions what to check or how to clear?
Thanks in advance
did you change the correct battery ? when you took the lid off the pir did it report that device ? or a different one ?
Thanks for reply
Yes changed out correct battery as control panel names PIR and tamper alarm activated when cover removed.
Replacement battery correct as suplied by original wholesaler to PIR device code
I suspect PIR may have developed a fault as old battery does not appear to have low voltage on tester and only very marginally less than that of new
Still scrathing head this end
just asking as ive seen detectors named incorrect before or they have got swopped around and you think your changing the battery in the dining room and its the one in the lounge so check what zone it says when yon take the lid off .
Having left the system overnight while considered my next move found that problem has now cleared and system reports all PIR voltage OK
Is this a problem with lithium batterries taking time to reach quoted voltage after installation? :D
Lithium batteries do not do that.
More likely that the PIR does not transmit a message to say the battery is now good when the battery is replaced. Some sensors only transmit when motion is detected or the battery is low. After a new battery is fitted in a PIR sensor the panel may no know about the new battery ( as in no longer low battery voltage ) until the sensor has had time to stabilise and then detect motion when it sends the first message after the new battery was fitted.
