Inhibitor(how to put it into the system)
7 Mar 2006
Shropshire
hi this may well be a stupid question but i have some Sentinel x100 and would like to place this into my central heating system how do i put this into the system which has been recently flushed out is it through a radiator or tank?
cheers brett
Have you got a Feed and Expansion Tank in the loft?
yes we do have a feed and expansion tank in the loft would it be ok to put into there ?
cheers
i will be draining the system in about a months time to add 1 more rad to the system would there be any harm in not putting the inhibitor in until then or do we need to do it straight away now
cheers brett
Do it now. It'll kill off any residual chemicals left from the flush.
When you drain in a months time (yeah, like autumn!) you can shut all the rads to hold the elixir or just keep what you've drained and tip it back in. If you're soldering, you should flush the work area's pipes.
If you're as mean as me, you can keep the drain-off in buckets (or a clean swingbin fits mine) and tip it back in.
Obviously, if you get any sediment out, don't put that back.
just another quick one if i wanted to put the inhibitor directly into a radiator what is the best way of doing this how do i pour the sentinel into a horizontal valve without spilling over the floor is there any kind of device used to do this or am i just being really stupid here
brett
like this :?: :?:
yes that is exactly them :) how do you get the inhibitor in without it going all over the floor
cheers brett
turn off the valves
slacken one ene and drain water into tray or similar
remove chrome plug
screw in 1/2"" bsp m/f elbow
tighten the end you used to drain
pour it down the elbow
remove elbow and replace plug
open valves
or get one of these
