Inhibitor
4 Aug 2008
Cambridgeshire
Replaced shower room rad with towel rail and when began to refill system, noticed leak on gate valve by water pump. It had a lot of limescale on outside so think it had been very slow leak for some time. Emptied system again but while removing faulty gate valve broke plastic cover on Grundfos water pump 15/50 - damn. It is switch from 1 to 3 that no longer moves. Plumbing shop reckon it is still set to 3 and this is correct setting so could refit as is.
Came on here to look for advice and saw posts about using inhibitors when have drained system. I've drained it twice so intending to buy Sentinel X400 as suggested but unsure where to put it. Read about F&E tank. I have a BoilerMate II so will I have an F&E tank in the loft? How does it work - will this water and inhibitor just end up in the rads and boiler? It won't be in bath water will it?
Thank you for any guidance.
PS I used the Alpha combi boiler instructions to fit a diaphram to restore hot water and it worked like a dream - thank you for fab resource!
Came on here to look for advice and saw posts about using inhibitors when have drained system...... but unsure where to put it.
Stick it in the New Towel Rail.
Nah, you want this for that...
