I will be moving a radiator to a new position and will have to drain some of the water off.The combi system was installed about ayear ago,flushed and then inhibitor added.My question is can I re-use the water/inhibitor mixture that I will be draining off or should I start afresh and drain every thing down.The rads are all fed from the boiler in the loft and are all drop feeds.
