Well, not having much luck with out plumbing of late (fog horn toilet, leaking pipe on boiler, this and also a cold tap not working)....anyhow.
Underneath out toilet (Ideal - about 5 years old), there is a flexible pipe which looks like it feeds in to the cistern part of the toilet.
The other day, we noticed that the pipe was leaking, which after feeling around, looks like it is between the nut and the toilet itself.
I've tried tightening the nut (very difficult to get to due to location near the wall), but that seems tight already.
I've turned the water feed off, and drained the cistern. Still some leaking, but very little coming out now.
I've tried opening the top of the cistern, but it is connected inside.
The top of the cistern has a dual (large and small) flush. I've tried untwisting it, but that doesn't work.
Any suggestions what might be wrong, and how to fix it?
Thanks.
Chris
Thanks.
Chris
