inner leaf block work around external door.. return it?
5 Oct 2022
Hi all, i'm self building a porch and have got to the DPC.. building control are happy so far.
I've got a dpm lapping over the inner block work and about to put the dpc and first course of blocks on.. couple of questions
Doorway - Do i return the block work to 'meet' the outer leaf brick and seal the cavity or just leave it open and seal it with some kind of reveal? (door will be fitted into the outer leaf)
What about the floor cavity at the doorway... feels like it needs a doorstep of some kind?
And finally. dpm and dpc.. should i use gobbo between them or just between dpc and blocks?
Don't close the cavity with block work, that went out about 15 years ago. Use a cavity closer. Everyone sells them including screwfix, toolstation.
The second question will depend on what floor surface you use.
If your asking if mortar goes between the dpc and DPM. No. You may need to stick them. Some kind of glue might be the thing but ive been out of the business too long to say.
