Hi
I have one inch to spare when i put my car in the garage .
Impossible too bring the door forward so i am thinking of taking out a portion of the rear wall which is constructed of blockwork .... there is a cavity and then an outer brick wall.
Is it possible to only remove the blockwork which would give me approx 100mm plus some cavity space.....
100mm would be sufficient. The blockwork supports the wooden roof supports.
Could i use STRONGBOY/ steel props to support the inner blockwork whilst i insert a lintel ?
If so what sort of lintel ?
The cut out would be about 2 metres wide and approx 1 metre high .
If my suggestion above is ok then how many Strongboys required ?
I dont wish to alter any of the outer wall.. just the inner block wall.
If the above is a no no then your professional advice would be greatly appreciated.
N.A.
N.A.
