inspecting old rads for imminent pinholes or failure
13 Jan 2008
Cambridgeshire
I realise that old radiators will die eventually and I have replaced many of mine over the years. I believe the usual failure mode is a small black pinhole which leaks where the corrosion eventually breaks through.
Has anyone any tips for inspecting rads to detect this kind of problem earlier e.g. a magnet?
..or are there other ways a worn-out rad will fail?
If you keep an inhibitor in the system, corrosion will be cut down to the absolute minimum. The only time corrosion can happen is when fresh water is introduced carrying oxygen.
As for testing - pressure test? Increase pipework pressure to a much higher than normal rate and if there's a weakness, it'll fail. Hold the pressure to test for slow leaks. Can be done with air instead of water to minimise mess.
Course, could force a failure elsewhere too, such as concealed pipework, or cause a problem that would never have occured under normal operation so not really recommended.
I have been to house's that I know for certain the rads have been in for at least 35 years, were used on open vent then changed to a Combi sealed system, one of them for the last 18 years, and still no problems, what is it with modern radiators then, or do we need to ask, basically someone in their 20's could buy a house, live in it for 40years with no problems, lasted them a lifetime.
Towel rails, so much crap with them, crap fixings, dodgy welds, don't get hot in the middle, no instructions but need flow and return a particular orientation blah blah blah, modern britain garbage.
Mmm 35 years - not my old dad`s house was it ;) I installed a simple system with a Parkray in c. 1973 and he moved out in 2008 - I think :oops: Kept a jar in the cupboard with a nail in the Fernox solution - next to the jar with his gall stones :eek:
Because towel rails are specced by women for the fashionable look.
Efficiency and build quality are rarely considered in the one room where being warm really matters.
It's not a british thing by the way, same all over the western world.
