I had an inspection chamber (precast concrete) in my garden covered with a piece of ply. I decided to fit a proper cover on it a couple of weeks ago, rectangular galvanised cover with a metal frame. I mixed up some 3:1 mortar using building sand, sprayed the precast concrete with water (been dry for a long time and it was a warm day), laid a bed of mortar and put the frame on this. Left it to go off for a couple of hours and then put the cover on. Then again using 3:1 mortar I haunched around the frame.
The next morning I noticed some cracks in the mortar but didn't worry about it too much. The last few days I have noticed more cracks and I was thinking about redoing the haunch. Today, I noticed the whole thing (frame and cover) will move if I kick the edge of the haunch.
I need to redo it and I was hoping one of you could tell me where I went wrong. Did I use the wrong mortar mix? Or is it because the precast concrete has a smooth surface so there is no key for the mortar? How should I do it so it is solid and doesn't move?
Thanks for your help.
