Instaling cat 5 & satalite cables
1 Jun 2010
London
I'm in the process of re-boarding and plastering my downstairs ceilings i thought that this would be an ideal time to instal a satalite cable and cat five cable to the three bedrooms upstairs and bring them altogeather under the stairs, the thing is i don't have a clue how to connect them
I have virgin media cable coming in the living room i have enough room under the floor to physically get under to run cables.
My question is can they all be connected to watch tv in all bedrooms.
Any opinions or advice are welcome
Thanks in advance
First what are you trying to do? multiple sat/cable boxes? multiple TVs from the same sat/cable box with terrestrial as well? If the latter are you considering upgrading to the former in the future?
Secondly what equipment and wiring do you have in place at the moment?
Without trying to sound to stupid, i thought i would future proof a little while i had the opertunity. Were not currently living at the property so i thought i could get some cables into the bedrooms for tv, again i have no idea how this can be linked to the cable tv, a friend suggested that i put computer cables in as well as it is safer to have computers hard wired than all on wifi again im a complete numptee with this and thought i could get some sound advice here.
Cheers.
you can split your main cable tv cable into useing a F splitter but i dont know how many times... iv done it so i can get cable in 2 rooms.
What you should plan for is enough cable to run three separate networks. Here's what to do...
Distributed TV using aerial cable:
The aerial output signal from your Virgin box needs to go to a hub point - in your case it sounds like this will be under the stairs. There it will connect to an amplified splitter. This mains powered box will give you the output signals that you'll then wire to each bedroom.
The aerial amps come in three flavours. The most basic type cost £20~£30 for a 1 in: 4 out device, like this one from [urlhttp://www.argos.co.uk/static/Product/partNumber/5346161/Trail/searchtext%3EAERIAL.htm]Argos[/url]. The just multiply the signal, nothing more.
Next up in quality are the amps that allow 9 volt to pass through for remote control, like this Philex one for less than £20. (Remote control of your cable box is a bit trickier than with Sky boxes which have the feature built-in ready)
At the top of the heap are the full signal distribution amps. These do the 9V pass, have more outputs, and can combine FM DAB Freeview (TV aerial) as well as the signal from the cable box, so no matter what you want to watch or listen to you'll have the correct signal at the socket. The cost is around £50~£80 for something such as this Labgear box. If you are planning on staying in the house anylonger than 5 years it's worth the extra investment.
Video & Audio over CAT5e
This isn't really a network. It's simply using CAT5e (or CAT6 which is now becoming popular) as an alternative to AV or HDMI cables. The CAT cable on its own is dumb. It needs adapter boxes on each end called Baluns to convert an AV signal in to something that will travel down a CAT cable and then convert it back again at the other end. Baluns range in price depending on the job they need to do. A simple video (yellow) and audio (red & white) balun pair might cost less than £30. At the other end of the scale is the Balun pair for converting HDMI and also carrying remote control signals back down the same wire. Those might cost £200.
Video & Audio over computer network
This is a true network. The AV signals are converted in to IP packets that can travel via a router to various distinations inyour home. This sort of system would integrate with your existing (or new) computer network. One socket on the wall in a bedroom could give you your broadband connection, access to your home server, and all of the AV devices currently hooked in to the network. Ball park figures for this sort of solution range from £2000 ~ £5000+
For your cabling at home, I'd recommend you go with two decent quality satellite type aerial cables to each room, and add 3 CAT cables per network wall socket location. Put a network socket behind each TV point as well as the ones at 450mm floor socket height. Run all the cable back to the hub point under the stairs, Label Them!!!, then decide what you plan to do with them once the dust settles after the build is complete.
Agreed, bringing everything to a central point is the way to go. That way you can easilly connect things to accomodate whatever equipment you have at a particular time.
You should install at least two coax runs from the central point to each TV location. For the main TV location you should run more as if you go for a "one box to all TVs setup" you are likely to want SAT/CABLE feeds coming in , an arial feed coming and and also an arial feed returning to the distribution gear.
For coax runs you should use coax designed for digital satellite TV. If any runs will go outside I strongly reccomend foam filled coax (e.g. WF100) as the cheaper extruded plastic stuff can act as a pipe carrying water into equipment and do serious damage.
Some of the HD over cat5 soloutions require two runs of cat5 so add that to one for your network and you are up to three per room. Four may be a good idea as it will allow you to use a couple of peices of network gear in there without having network switches all over the place.
Thanks for your replys, i will try and digest the info and look into sourcing some equipment.
Again many thanks
