Due to have kitchen ceiling replastered and wanted to swap from central single light fitting to half a dozen downlighters.
I had thought the plasterboard would need to come down giving ample access to the joists and wiring etc but the plasterer has had a look and the plasterboard is sound (basically the existing plaster loosened the artex to which it was applied, and the whole lot is coming off leaving solid sound boarding).
The plasterer says therefore don't remove the boarding, and also said the spots could be fitted after plastering.
I can't see this myself because surely the electrician will need to span joists etc to run the wires?
Is it possible to retrofit spots in what would be a finished and freshly plastered ceiling or am i better to get everything run before the plasterer makes a start?
Cheers.
Chris
Cheers.
Chris
