When Ben Bailey threw up/(built) our house 10 years ago they managed to install two of the largest, ugliest inspection chambers in our garden.
Looking at the photos below, I wondered if it would be possible to install some plastic chamber risers of the same diameter as the chamber base, obviously with the correct access cover, and then back fill the remainder of the original chamber after removing the top concrete ring so that we can plant around it (with non invasive root system plants).
The diameter of the base is 500mm, which I am having difficulty finding risers for on the web.
Sorry if these images are too big.
