Install Worcester Highflow
23 Jan 2006
London
Hi all
Got a customer who is very keen on a new HE Worcester Highflow to replace his old balanced flue Highflow.
I've never installed one of these and Worcester have removed all the installation instructions from their website so I can't make an assessment of how tricky the installation is going to be. The guy has kitchen units either side of the existing unit with about 10mm clearance either side. Kitchen put in after boiler...
Anyone installed a Highflow? If so how tricky is it and can it be done with sod all clearance to the side?
Cheers
Very easy install, comes with detachable jig for plumbing, pipework in from the back and below boiler to front, boiler then rolls onto jig,it has wheels, also has a condensate pump built in and a decent length of tubing, fits into a standard appliance space nicely.
Sorry also meant to ask:
When removing the old one, is it easy to drain the primary H/E and thermal store?
Cheers
relatively easy, drain cock at base, front of boiler, right side but very low to floor.
Are there 2?
1 for primary h/e & one for thermal store?
Its just that I don't fancy lugging it out full of water - its heavy enough as it is!
Ta
If i remember you can split them down to help remove them, should break in half and all the panel's come off. Takes a bit of messing around, but if your on your own, it safe's a few pint's of sweat/blood.
Yes, just the one drain off, I usually split the the boiler in sections to remove.
Ta
But you can pull it out on its own wheels, until you get to the steps that is!
Tony
